Any trick to driver side axle?
Old 04-21-2005, 11:17 AM
Omniscient
warm butter on toast
Omniscient's Avatar
Default Any trick to driver side axle?
Well, I'm putting my car all back together. I'm gonna worry about the wiring last. Anyway the thing is, the passenger side axle slid right on. I just had to press it a bit and it locked all the way in. But the driver side goes on maybe 1/4th the way and doesnt budge. I think its the clip on the half shaft I'm not sure. i greased the bejesus out of the axle too. So Is there a tool or method I could use to get it on there?
Edit~Also, on the passenger side, the ball joint nut is kind of snug, not torqued on, but the actual thread on the ball joint is spinning. Is that ok if I put the kotter pin in?
