what does boosting most effect?
hey guys. quick question. what does boost/turbo most effect, hp, or torque? or both the same. the reason being, stock hondas generally arent really quick cars. if one were to boost it, would that bring the torque right up with the hp? thanks.
4500rpm hesitation
Yes, it will bring the torque numbers up.
You will usually NEVER see a torque number higher then a HP number on a Honda, however.
It is dependant on the turbo though. The HKS ( I think) potato-turbo is specially made for lowend torque and almost no highend, and I have actually seen a torque number higher then a HP number on a honda motor with that turbo, but it wasnt all that much worth it due to the fact that it lost so much high end.
the RS*R S2000 is the one im talking about btw
as a broad statement...
supercharger will increase low end power, whereas a turbocharger will increase top end power
if u wanna know why, do your research here..
www.howstuffworks.com
horsepower is a measure from torque.
On permanent hiatus
A good tune will bring the torque numbers closer to the HP numbers on certain turbos, such as the Greddy kit. The HP doesn't increase much from a good tune but the torque number comes really close to the HP number.
