motor swap
motor swap
yes i know alot of post like this but this one is kinda specific.. if i was swaping from N H23 to an h22a 200 hp motor what else will i need to purches to make the swap to work for example will the water pumps swap over will the starter swap over power steering pump ext.. anything else i would have to buy ? thanks in advance to anyone who has done this
RIGHT Wheel Drive!!!!
I haven't done it personally, but I have assisted a few people. Assuming you get a long block, tranny and an ECU... Since the engine will be off the car, you might think about replacing:
The clutch
All Belts
Oil pan gasket,
Valve cover gasket and grommets
Timing belt, and cover gasket
Engine Mounts
Alternator
Dizzy (Distributor)
Plugs and wires
Intake Manifold Gasket
1/2 shafts (CVs, axles whatever)
Front Wheel Bearings.
Make sure you get all the necessary harnesses. It took 3 of us 1 weekend to get the a blown engine out of the car, and 2 weekends to get the new one in replacing most of that list.
The clutch
All Belts
Oil pan gasket,
Engine Mounts
Alternator
Dizzy (Distributor)
Plugs and wires
Originally Posted by iwubmybb4
does anyone have a write up of a f22a4 (honda prelude S) to a JDM h22a motor swap?
ive attached a helpful text file, it covers everything u need to know
good luck
