auto to 5 spd conversion
Has anybody done an auto to 5 spd conversion in a lude? i was thinking of doing one in mine but it dont know how tough it will be. Also im not sure what all parts i'll need, i think this is most of it but correct me if im wrong...
Trans
master cylinder
slave cylinder
ecu
clutch
flywheel
Also how much can i expect to pay for all this stuff and should i just check salvage yards or what??
Trans
master cylinder
slave cylinder
ecu
clutch
flywheel
Destiny SeekerZ
I know I will eventually swap a 5-speed into mines later down the road. So I only got one question.
After you swap the thing, is there any difference between a auto > 5speed compare to a factory built original 5speed.
Like is there an advantage and/or disadvantage on either side?
Dont forget the gauge cluster. Well not really a big deal but the auto gauges have the shift lever position indicator and the manual does not. The rear motor mount is also different as well, not sure if that will be included with the tranny or not. And of course the shift boot and trim ring.
Andrew
Andrew
