greddy evo install question
hello all I finally got my greddy evo and put it on except for one stubborn a$$ rubber hanger. Are there any suggestions on how to get these rubber hangers on easy? thanks
i feel ya bro. damn when i put on my apexi ws, them rubber hangers were a biatch, along w/ the rusted nut/bolts.
a friend and some muscle power. on my last and final hanger i stuck a screwdriver in the hole and tried to stretch it as much as i could and lubed the hook so its be easier to slide the rubber hanger over it.
which hangers you have? the ones with the 2holes or the ones with 2holes and a peice open in the middle? either way its very easy and if you look you'll figure it out.. theres a spot in the factory position to hang the rubber to find the clip and place it thru one of the opening and then place the hanger bracket on the exhaust piping/canster thru the other hole (IMO you should bend the clips so they make a hook instead of a straight line, helps keeps system from falling)
thanx for the replies...i forgot to do a search ... found some good ideas and so i am gonna try a couple of things...i got them factory rubber hangers w/ 2 holes and that slit in the middle...yeah man all night we were tryin to muscle that thing in...i'm gonna try it tonite after work and hopefully it'll be done. Thanks again
i neva had any trouble hanging mine nor any of my friends own but i did learn to bend the ends of the hangers thru the rubber to help keep them from falling off the hangers
