REALLY need some help - ECU Engine Codes
Hello,
For the longest time (about a year now) my lude (JDM H22a in a 92 H23 chassis) has been giving me engine codes when i'm in vtec for too long, as well as keeping me below ~6700 rpm (revlimit). I know the H22 is supposed to go more like 72, 7400. SOOO i just jumped the 2 pin diagnostic connection and it gave me an engine code of 22 @ 2 long blinks, 2 short blinks. I checked the diagnostic code chart at www.92lude.com and that code doesn't even exist...
Any ideas? am i missing something?!
thanks in advance!
thanks in advance!
TROUBLE CODES
0 - ECU
1 - o2 Sensor
3 - MAP Sensor
5 - MAP Sensor
4 - Crankshaft Position Sensor
6 - Engine Coolant Temp Sensor
7 - Throttle Position Sensor
8 - TDC Position Sensor
9 - #1 Cylinder Sensor
10 - Idle Air Temp Sensor
12 - EGR Valve Lift Sensor
13 - Barometric Pressure Sensor
14 - Idle Air Control Sensor
15 - Ignition Output Sensor
16 - Fuel Injector
17 - Vehicle Speed Sensor
20 - Electrical Load Detector
21 - VTEC Solenoid Switch
22 - VTEC Pressure Switch
23 - Knock Sensor
30 - A/T Sig A
31 - A/T Sig B
41 - o2 sensor heater
43 - Fuel Supply System
0 - ECU
1 - o2 Sensor
3 - MAP Sensor
5 - MAP Sensor
16 - Fuel Injector
23 - Knock Sensor
30 - A/T Sig A
31 - A/T Sig B
