How do I remove caliper paint?
The owner before me painted his calipers on the front disc brakes.
Well, the caliper paint wore off in about 5,000 miles. It really looks like ****, but I've never gotten around to redoing it.
Since I'm chaning out the rotors and pads, I'm going to do it now.
How can I remove the old crackling white pain that he put on it?
And, how can I paint it to avoid it flaking off again so quick?
Did he just use a ****ty paint brand, or does it always come off that quick?
Thanks,
Brian
Thanks,
Brian
I guess I will have to use some thinner. If I were to just paint them black, then the white underneath would just continue to flake off, and the black would go with it.
I won't need to bleed the brakes so I won't be able to do that either.
Maybe I will try a bristle wire brush as well.
cx power!
Location: berkeley, ca --> la, ca representin' tha 510&626
Originally posted by wrigh003
Brake fluid does a pretty good job of eating paint, so just don't be too careful when you're bleeding the lines.
Fight Rice
well instead of bleeding the brakes to get the brake fluid, why dont you just get some cheap a$$ brake fluid and apply it to the calipers with a towel or something to get the white paint off.
Okay, so I will buy a dollar worth of brake fluid and rub the calipers clean.
But, when I repaint it, the new paint won't stick because of the brake fluid right?
Sucks.
Maybe I will just be a lazy ass and put the black paint on top. My rationale is that any white paint still on after 2 years most likely will stay on at this point. Right? Right?..... right?....
Sucks.
If you're going to go to the effort to paint them again, might as well do it right, right? Get a wire brush and get as much of that old **** off as you can, then paint them back with high-temp engine enamel, as many thin coats as it takes to cover it up good. And while you're down there, I know you said you weren'y going to need to bleed the brakes- but maybe a nice set of stainless stell brake lines would look cool, too.
