Reverse Light Woes
Hater
Reverse Light Woes
Blah, so 92 prelude with 95 H22 and manual tranny. The problem was that the reverse light would just stay on even when the car was not in reverese. I've replaced the reverse light switch with a autozone one and it was fine for like an hour, then the problem happened again with the new swiitch so I've had to disconnect the swtich from time to time. Sometimes, when the lights come one, you can pop the car in reverse and pop it back out and the lights go off, so I'm assuming the problem lies in the tranny itself? TIA
Hater
Originally Posted by blkv6cpe
It is your back up switch on the transmission.It is bad. I had the same problem. replaced it and no problem.
Duron
Duron
if the reverse light stays out when it's unpluged it's the reverse switch....get a honda one and problem will be fixed if the light comes on when unpluged it's a wiring issue
