4-2-1 or 4-1 Header for a GSR
Old 03-09-2005, 05:23 PM
OilCanBoyd
OilCanBoyd's Avatar
Default 4-2-1 or 4-1 Header for a GSR
I'm looking for a new header for my GSR and am thinking a DC Sports Ceramic.
Looks like the best price I can find is $255 shipped.
Question. What would work better 4-2-1 or 4-1.
The car only has an SRI and this will be the last mod. Possibly a high flow Cat and exhaust in the future but thats it. Thanks!
Old 03-09-2005, 05:25 PM
EviLLLLSiNz
n00b
EviLLLLSiNz's Avatar
search next time. 4-1 is generally more midrange-high end power whereas 4-2-1 is low to midrange.
Old 03-09-2005, 06:26 PM
SP00NFed
FuK JDM
SP00NFed's Avatar
http://www.team-integra.net/sections...p?ArticleID=50
Old 03-09-2005, 06:30 PM
1turbodc2
got boost?
1turbodc2's Avatar
i got a 4-2-1 comptech stainless stell, and its good for the street, unless u are planning to run in the high rpms and do a lot of mods then go for a 4 to 1. (also have comptech ice box, skunk2 cams, skunk2 intake, apexi exhaust)
Old 03-09-2005, 06:57 PM
OilCanBoyd
OilCanBoyd's Avatar
Thanks!
Old 03-09-2005, 07:42 PM
dubcac
I
dubcac's Avatar
You'd benefit from a 4-1, considering your intake, intake manifold, cams, and exhaust are geared for high rpm power.
Old 03-09-2005, 09:54 PM
AP2
Moderator Alumni
AP2's Avatar
4-1 is better suited, however you may run into ground clearance problems when you approach low objects on the road you normally run over. Be more careful.
Old 03-10-2005, 11:14 AM
OilCanBoyd
OilCanBoyd's Avatar
Even if the car is stock. Not lowered or anything? And what happens if I have to go over a speed bumb or? How careful do I have to be? Thanks
Old 03-10-2005, 11:43 AM
Snoopy
been there done that
Snoopy's Avatar
depends on how low you are really. if you're dropped too low you'll find yourself coming in nearly sideways to clear most speedbumps. :reechy:
Old 03-10-2005, 12:00 PM
FooD2000
Still Water
FooD2000's Avatar
concerning your header? i'm sitting 3' off the ground on 16' rims, my header has never scraped, (if your concerned with the header). if anything, your cat will scrape first.
