turbo obd2 cat
dat thang got vtec???
turbo obd2 cat
i have an integra gsr turbo....as we all know backpressure is the enemy of all turbos. my car is a 98(odb2), what problems would i have if i gut the cat...besides check engine light.And is it really worth the money 2 convert 2 odb1(300-400 benos). any help would be great. and stay real and keep ur cars clean!!!! euro lights and big wings suck!!!!!!!!!!!!!!!!!!!!!!!11
On permanent hiatus
Why don't you get a highflow cat so that you can avoid the CEL? With the CEL on, your car will run in limp mode and probably very rich since the oxygen sensor isn't sending the proper data to it.
freshsqueeze
If you decide to go OBD1 you will have to get a OBD2 > OBD1 harness which will run from $50-$100 on ebay. Getting a OBD1 ECU will increase rev limiter(there are several on ebay that increase rev limiter anywhere from 8200-9200)change fuel/air ratios, and will remove speed limiter(this one I need...my '98 LS topped out at 115)
I
Gutting your stock cat won't cause the CEL to come on unless you don't plug in the O2 sensor. I just ordered an OBD2 Carsound high flow cat for my 97 LS, so you do have options.
As for converting to OBD1, simply using an OBD1 ECU will not change the rev/speed limiters or the timing and fuel. You have to get an aftermarket ECU for that...and since you are turbo, that isn't for you. If you go OBD1, go Hondata.
