Where is the Fuel Filter Located?
Jizz Maste12
Where is the fuel filter located on the 6th gen coupe I4 and is it hard to change it your self or do you need to take it to the pro's?
you DO NOT need to change the fuel filter on the 6th gen. It's located inside the fuel tank i believe and it does not need to be changed. Call the dealer and they will tell you the same thing...
A fuel filter should be replaced every 30k miles, thats like saying you never need to replace an air filter.... I don't know about 6th gens, but it's right on the firewall in a fourth gen. If you follow the fuel line from the fuel rail inlet, it should connect right up the the fuel filter if its like a 4th gen is.
09-15-2006 07:07 AM
pomansouth
4
07-02-2002 09:41 PM
