camber kits?
Old 03-03-2005, 05:45 PM
flytojungho
flytojungho's Avatar
Default camber kits?
do you need camber kits for dropping s2k's?
Old 03-03-2005, 09:50 PM
Provocateur
On permanent hiatus
Provocateur's Avatar
Depends on how much you drop it and whether or not the alignment shop advises you to get some. Vague answer for vague question...
Old 03-04-2005, 05:12 PM
flytojungho
well.. for example, it's recommended to get a rear camber kit for 1.8+ lowering on my av6.. I'm asking in advance so i DON'T have to spend money twice on alignment when i can only get it done once with the camber kit(if I know it'll require a camber kit in advance)
Old 03-04-2005, 10:02 PM
Provocateur
On permanent hiatus
I think anything over 1.5" will most likely require a camber kit. 0-1" will not and 1-1.5" will require one if the alignment place recommends it.
Old 04-01-2005, 11:28 AM
RDN
Red Dragon Nitro
RDN's Avatar
Best thing to check is toe, thats the thing that'll eat up ur tires unevenly the most. I have -1.9 camber all around on my lude and 0 toe and my tires have worn evenly for 22,000 miles.
