Idle adjustment on a '96 ?
I found the screw on the TB that is supposed to adjust it, according the the Haynes manual, but turning it does nothing. I need to advance it slightly. It's idling below 500. That makes it a little rough. It also then said something about removing a fuse, unplugging the IAC ?
Any help is appreciated. I don't want to pay an hour of shop time for this.
IAC in yellow circle.
after you unplug the IACV a CEL will come up, adjust the idle with the idle screw with the IACV unplugged. once your done adjusting put the plug back in and pull the 7.5 amp radio back up fuse to reset the ECU and clear the CEL.
You just explained what I was having trouble understanding. Why pull the fuse? Okay, to clear the CEL. I also have OBDII interface to my notebook to clear it...but this is MUCH easier :-)
