Brake Master Cylinder
Old 02-20-2005, 11:40 PM
ChassisInnovations
HAN Authorized Vendor
ChassisInnovations's Avatar
Default Brake Master Cylinder
Can I use a brake master cylinder from a 98-01 Integra on my 94-97? I know that the brake lines are slightly different, but those are being changed anyway for an ABS delete. I just need to know if the 98-01 MC will bolt up to a 94-97 brake booster.
Old 02-21-2005, 05:14 AM
SP00NFed
FuK JDM
SP00NFed's Avatar
how do you delete your abs? because i know i have axles that aren't abs so my abs doesn't work....how would i take out the abs unit?
Old 02-21-2005, 10:07 AM
ChassisInnovations
With 94-97, you need the four under-the-hood brake lines from a 94-97 Integra RS. You also need an RS proportioning valve (94-97). To keep the 1" master cylinder, you need to have one of the brake lines bent and re-flared, or you can get a SS line.
With 98-01, you just need the four under-the-hood brake lines from a 98-01 Integra RS and a prop valve from a 99-00 Civic Si.
