SRS AND CHECK light on after unpluging the fuse
I was installing cd player into my Honda Accord 99. But something happened and fuse went out so in the order to check the fuse i unplugged each fuse check it cause i never knew that there is a fuse on passenger side so i replaced and cd player works now as i discussed with other forum member her who helped to solved this problem https://www.honda-acura.net/forums/s...62#post2185462
But the problem i have now is that after turning on the car. The SRS and Check light remains on it doesn't goes out as it should be. Is there something i did wrong or damaged or is there way to reset it. I mean unplugging the fuse damage the engine. Please let me know how i can fix this thanks
