quarterpanek repair
Old 02-13-2005, 11:50 PM
c-dubb
c-dubb's Avatar
Default quarterpanek repair
ive got a 93 del sol and lola is suffering from tha famous honda fender/quarterpanel rust and its very rainy up in the northwest and i have parked outside for years so i was wondering there is a small amount of rust where the back bumper clips into the quarterpanel and small amounts above the trim below the driver side door, i was wondering how much it would cost per quarterpanel/fender typically? and is it worth it to redo all rust and fixing it so its gone for good...
Old 02-13-2005, 11:58 PM
depends on how bad it is, if it is a small spot sure go right ahead and have it fix, most shop will probably charge u around 300-400 for this job.
if its starting to rust out, then
in the long run replacing the quarterpanel will be cheaper. Rust will always be there, even if u grind it off eventually through the years it will come back.
got pics?
Old 02-14-2005, 12:36 AM
c-dubb
c-dubb's Avatar
500 for all spots of rust/?
