Tachometer
Old 02-13-2005, 09:37 PM
Josh123
JB
Josh123's Avatar
Default Tachometer
I have a 2.5 inch tach and i was wondering if there is any other way to hook the green wire of the tach. I know it goes to the negative side of the coil but is there any other way????? This is for a 94 honda civic cx with no existing tach thx
Old 02-13-2005, 09:38 PM
Josh123
JB
Josh123's Avatar
If i have to go to the coil how do i get the rotor out under the disributor cap thx
Old 02-13-2005, 10:17 PM
Provocateur
On permanent hiatus
Provocateur's Avatar
I think you can hook it up to the RPM signal wire going directly to the ECU. I am not sure which one it is, but if you find a pinout, it will show you.
Old 02-13-2005, 10:42 PM
Civic2Scooby
Civic2Scooby's Avatar
actually you can just use the blue wire that already goes to the back of your gauge cluster as it is the signal wire for the tach because all civics come pre wired for a tach. :thumbup:
Old 02-14-2005, 01:21 AM
Jafro
I'm made of meat!
Jafro's Avatar
Or if you want to know what the ECU pin is for the RPM sensor, check the civic page in my sig for a 5g wiring diagram. The center of that chart is the ECU pinout.
Old 02-14-2005, 08:05 AM
JaVa_230
JaVa_230's Avatar
its the light blue one. if you look at the pin there should be no connection on the back of the gauge cluster.
