what do u thinkof my setup?
this is what i wanna do the stuff in bold is the stuff i am proly gonna buy
1999 honda civic si b16a2
Dran Gen III turbo
t3/t4 ball bearing turbo turbonetics
HKS SSQ bov
Apexi N1 exhaust
Block:
Golden eagle sleeves (82mm)
Wiseco pistons 9:1
Eagle rods
APR head studs
Fuel
Aem fuel rail
Aem fpr
RC650cc injectors
Walbro 255 LPH fuel pump
tial 35mm wastegate
i know im proly missing some things and i would GREATLY appreciate any suggestions u have you about setup. also i wanna run some where around 350-400whp what would be a good clutch for me?
Dran Gen III turbo
HKS SSQ bov
Apexi N1 exhaust
Block:
Wiseco pistons 9:1
Eagle rods
APR head studs
Fuel
Aem fuel rail
Aem fpr
RC650cc injectors
tial 35mm wastegate
check this out this is the setup that you will need for thoose #'s https://www.honda-acura.net/forums/v...o=view&id=1197
On permanent hiatus
Good setup. Don't bother with the fuel rail. The stock one is good for much more hp than you plan on pushing. What are you doing for fuel management? Hondata? You might also want to think about a 3" piping exhaust.
Still here... sorta...
Originally Posted by hector200
check this out this is the setup that you will need for thoose #'s https://www.honda-acura.net/forums/v...ew&id=1197
I ran an ACT XTSS for a while but I drag race the car and it died after about 30k mi. I went with an XTR6 this time. It's naaaaaaasty. :yes:
I'd go with a bigger bore too...
You will need some kind of EMS for that setup to make the hp you want. Good goals though. They are very attainable.
yea right now my car is already tuned with hondata at 8psi, what size bore would u go with? 84mm? or what
yea i think im gonna do a custom 3 inch and take out my cat
also lookin into gsr cams
Just go with ITR cams.... of course they're going to be more expensive.
The bigger the bore the more torque you can create. Since you did all that you did, you might as well have bored as well, but oh well. It sounds like a decent setup. I'll be interested to see what you make, but you're going to have to go into the high teens/low twentys of boost pressure to get 350-400 whp out of it.
If you're in a place that you can remove your cat then more power to you. The 3" exhaust will help the spool, that's for sure. Do you have pics of this beast?
yea i was lookin online and found brand new ctr cams for $470 and itr cams for $407,
so u think it would be wise to go with 84mm bore?
yea im for sure gonna take out my cat but alot of places i have asked but they wont do it cause its illegal(but i live in mn and we dont have smog test) how hard is it to just take out the cat and put in a starigth pipe?
On permanent hiatus
I wouldn't go with ITR cams on a turbo setup. I would go with something high lift and little/no overlap from Crower or Skunk2. That would require a valvetrain upgrade of course. You could always get some headwork done to increase flow.
