the start of my trunk
ChicagoLand Accord Club
so i have the sub and amp installed. i started to make a cardboard outline for the piece of wood ill be putting in. the sub is behind and the amp will be mounted where the 2 pieces of paper are.
I was going to install a board similar to that but I have a new idea. Im building an amp rack for one amp and im going to hide my 4 chan amp, xm tuner and tv tuner behind the panels in my trunk.
too bad the amp isn't smaller.
I mounted my amp under my front seat, then ran the speaker wire to the box. it's a pretty clean setup and I could remove the box at any time if I need the space.
Also, when or if your done with that template, can you ship it over to me?
I want to use a template to make a board also but im lazy to make one.
The last cut out I made did not come out so great.
haha yeah i did it very fast i gotta make some changes to the end pieces.. and who ever asked wut i am going to go with the sub, that will be behind it all. so when u open the trunk all u see is the amp.
