custom radiator for swap
Old 02-02-2005, 09:15 PM
BLACKEN
BLACKEN's Avatar
Default custom radiator for swap
Is there a company that make a radiator to fit into an EG with a H series swap?
Old 02-02-2005, 09:16 PM
westcoaststyle
Still here... sorta...
westcoaststyle's Avatar
Is the clearance that bad? Why not just get a single core fluidyne? I'd need pics to properly answer this question as I can't visualize how close the motor is to the rad...
Old 02-02-2005, 09:22 PM
We used a Integra Radiator for the H series swap. You just need to make the brackets for it
Old 02-02-2005, 10:00 PM
BLACKEN
BLACKEN's Avatar
I was just readin up on the swap on some site and they said custom rad and axles. Maybe the site was out of date. Thinkin about doin it, just not sure if I can make it handle well or If I want to spend the money to do so.
So whats up with the axles? Which one do you need? Also which cat?
Hey RicoD which fan did you use on the rad?
Old 02-02-2005, 10:59 PM
SamuraiBill
SamuraiBill's Avatar
I have one of these with my swap and there is plenty if room about 8 inches clearence but that is guess buy I am certain its not far off.
Austin
Old 02-03-2005, 06:42 AM
westcoaststyle
I also used a Teg radiator. Take a look at this DIY for more info: http://www.hybridgarage.com/tech/jsrad/jsrad.html
I use a FAL fan for a Civic on my rad and it works great. Had to cut up the mounts a bit to make it fit, but works like a charm.
