transmission oil change....
Old 01-31-2005, 02:05 PM
oldskoolcivic
oldskoolcivic's Avatar
Default transmission oil change....
will 10-30 motor oil work on the manual tansmission (d15b7 tranny)? i went to napa and they said its ok to use it, and needs 1.5 quarts
Old 01-31-2005, 02:59 PM
PDiggityDogg
Meanwhile, up in The D
PDiggityDogg's Avatar
they make mtf for a reason
Old 01-31-2005, 03:11 PM
VPUPPY
VPUPPY's Avatar
get the honda MTF.
Old 01-31-2005, 05:32 PM
oldskoolcivic
and where do i get that? (honda trans fluid) and since i already bought the 10w 30 oil, its ok to use it right? the dude at napa said its ok and its from the manual that hes reading. my tranny has 170k on it
Old 01-31-2005, 06:34 PM
Wharbone
Wharbone's Avatar
It's ok to use the 10w 30 temporarily, but the Honda MTF is cheap. Just use it and be done with it. You get it at the dealership.
Old 01-31-2005, 06:46 PM
dpkelly
1999 Civic Driver
dpkelly's Avatar
The Chilon's manual for my '92 civic says to use 10W30 or 10W40 motor oil. 10W40 is for highway driving. There is an upper and lower drain plug. The upper one is for level checking and adding more fluid. The lower one is for draining it. I plan to do mine tomorrow night.
I guess I'll use Honda MTF since it has been doing me well all these years so far.
Old 01-31-2005, 08:58 PM
westcoaststyle
Still here... sorta...
westcoaststyle's Avatar
Motor oil is only to be used as a temporary solution. Do not use it long term. Use Honda Manual Transmission Fluid. You can use that oil you got in your engine - hence its title: MOTOR OIL!
Old 01-31-2005, 09:36 PM
Kabooki
Kabooki's Avatar
I am lookin to change my tranny fluid soon/check it. Shifting seems kinda crappy.... How would I go about draining/filling it? Just wondering cuz I know you gotta fill it kinda weird.
Old 02-01-2005, 02:49 AM
Hondaisok
Hondaisok's Avatar
91 Honda Civic, 1.5
My manual and Haynes both say to use regular 10W 30 oil in my manual transmission.
Old 02-01-2005, 05:32 AM
Running925
Your Powder Coater
Running925's Avatar
Just use the HONDA MTF! They make it for a reason!
