99 civic turn signal help
Old 01-29-2005, 12:04 PM
heath99SI
heath99SI's Avatar
Default 99 civic turn signal help
I have a 99 civic and the front left turn signal is blinking twice as fast as normal and it does not flash the signal. When I lock and unlock the car the signal flashes. any one know whats going on? i would greatly appreciate any help. thanks
Old 01-29-2005, 12:20 PM
onebadassdx
onebadassdx's Avatar
check your bulbs, the rear one may be out
Old 01-29-2005, 01:19 PM
heath99SI
heath99SI's Avatar
sorry, i meant to say the front left does not blink the rear does. It does blink when you lock the doors with the key fob. ...so the bulb is still working..
Old 01-29-2005, 04:40 PM
gsrsol
slow and low
gsrsol's Avatar
your bulb has two filaments in it, the light works with your keyless entry because it is hooked up to your parking light wiring, and not the blinker wiring. change the bulb then come back.
Old 01-29-2005, 05:24 PM
onebadassdx
quick way to check, turn on your hazards and see if they all light up
Old 01-30-2005, 10:01 AM
heath99SI
heath99SI's Avatar
Default awesome
So it was the power inverter's cyntrifical relay, that connects the fuse and the power source that trifolds the power disfuncter into the the signal...... or not.....it was just the bulb, thanks for your help, i dont know why i make things out more complicted than they are. i really appreciate it.
Old 01-30-2005, 01:00 PM
gsrsol
slow and low
gsrsol's Avatar
lol thats cool glad we could help
