| Do It Yourself This is where you will find step by step instructions so you can Do it Yourself! |
Thread Tools | Display Modes |
#1 | |||||||
ABS light wont go off ...
| Sponsored Links | ||
#2 |
Hi
Well I don't know if this will help, but I got my 96' Integra broken into recently and they completely screwed up my steering column. After the wiring and everything was fixed, the ABS light was still lit. So I asked my mechanic if he could make it go away. He stuck his hand under the dash, and pressed some sort of reset button and the light went away. You might just need to get it reset somehow. I don't know if this helped somehow, but its just an idea.
#3 |
yeah i figure i need to have it reset but how lol? thanks for suggestion.
#4 |
I would suggest you to disconnect the main fuse( which you can find in the fuse box under the hood) for 5 minutes, then reconnect.Hope it'll help
Danny |
#5 |
anyone know how to reset thic thing?
#6 |
Probably similar to my '95 Integra... ABS has it's own little fusebox, & you pull fuse 1B or something...
But if you haven't fixed the problem, the lamp will just set itself right back on. Jumper your service connector like you're reading ECU errors. Watch the ABS light blink: long flash & long pause - this isn't the code yet. short flashes = first digit of code 1-second pause short flashes = 2nd digit of code long pause next code, or the same code keeps repeating...
JimBlake '03 Accord, '07 Civic '01 Saab 9³, '05 9²x |
#7 |
tried taking the battery negative off for 15 min and pullin abs fuses.
still comes on |
#8 |
If you disconnected the battery cable and the abs fuse and it still comes back on then there is a problem with the system, 90-97 accords have had a lot of problems with the abs system. Some of the problems are 1] If you remove the resovor cap and look inside of it and see metal shavings then the abs pump is bad 2] If the resovor is really low on fluid the the tall canister next to the pump is leaking. Either one of the problems will not effect your braking system. You can remove the abs fuses to disable the sysem and just ignore the light [ put a postit over the light so you dont have to look at it]. It is really expensive to replace either one of these parts.
#9 |
checke the 2 things mentioned above. and they arent the problem. im thinkin abs sensor on the axle broke or got clogged from snow?
#10 |
Is it really so difficult to read the error code? Then we won't have to guess.
#11 |
i do not know how to do it
#12 | |
Mr Clutch
Quote:
You might need your manual. Behind your glove box,.. there are two connectors....one for the ecu, and one for the abs system. I'm not sure, but if I had to guess, I would say the abs is the orange connector. Take a piece of wire , almost any piece will do, and jump the connector. Your abs dash light will start to blink and you'll have to know the number of times it does,.. and match them with the corresponding codes. I have two very important abs links on my desktop( on laptop now),.. that I can post when I get home. By the way,.. this has been covered a gazillion times. Do a search.
Le Enfant Terrible |
#13 |
It doesn't have it's own plug, it's the same connector as reading the ECU codes. Blue, with 2 wires. Jumper it with a paper clip, then turn the key on (don't need to start the engine). If you have both ECU & ABS errors, then both lamps will be flashing...
#14 | |
Mr Clutch
Quote:
I dont think its the same plug,... I'll have to double check. I thought the blue was for the ecu?? Are you sure it's the same for a 95 EX???
#15 |
I KNOW it's like that on OBD-1 Integra. I was assuming other OBD-1 were the same.
My '95 Integra does have 2 plugs, the 2-wire plug is the one I'm talking about. The 3-wire plug is for some kinda scan tool, before everything was standardized into OBD-2.
#16 | |
Mr Clutch
Quote:
I knew they werent the same . According to the Haynes Manual,... they're not the same either .
#17 |
The 1 and Only....
I say put a rag in ur fuel tank, light it and watch it burn....burn baby burn...that would solve all of your car issues.
Just kidding...sure something cheap can be done to fix it. |
#18 | |
Quote:
my motto: I live my life a quarter-pounder at a time. And for those 500 calories or more, im free. I need FRIESSSS! Two of them. The big ones. Oh, and i need them tonight. Youre lucky the double shot of BBQ sauce didnt blow a seam on your nugget box. There she is, 2 pounds of pure beef. My dad ate it in 9.0 seconds flat. Check it out, its like this. If i lose, winner takes my happy meal. But if i win, I take the burger and the toy. To some people, thats more important. [=http://board.accordtuner.com/] [/url] |
#19 |
ok i read the code. abs light blinked four tiems then paused then 2 more time. i looked that and its the front left speed sensor. question submerges where do i get one now
#20 |
First check to make sure the wire for that sensor is OK. Dirty/loose plugs anywhere? Cut the wire while wrenching on a caliper or shock??
The sensor's magnetic. It's possible that a pile of metal shavings are stuck to it? Take off the caliper & rotor, you'll see the sensor poking thru & sitting close to a toothed ring on the outer CV joint.
#21 |
im pretty sure i didnt damage it while doing my alarm, is it possible? cuz thats when the light cam on after my battery died after the alarm install. ill check if there is anything stuck to it.
#22 |
i have a 92 accord and my abs light just came on
and it was an abs sensor in one of the wheels wells its prolly not the problem due to you only your battery dying iuno. hope this may help |
#23 |
Yeah, I've had the battery disconnected several times. That's never caused an ABS error in my car.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
