85 civic problems,...ignition
Old 01-18-2005, 01:04 PM
manomite
manomite's Avatar
Default 85 civic problems,...ignition
I don't seem to have enough spark at my spark plug.There is power entering the top of my distributor from the coil but I can't tell if it's enough.some but not enough spark at the plugs.....help if you have any ideas on this....thanks
Old 01-18-2005, 02:03 PM
b16ahybrid
b16ahybrid's Avatar
Have you measured the voltage to know? or is this just a guess.
How old are the plug wires, whens the last time a tune-up was done?
maybe you need to do a tune-up, maybe the plug wires are bad....what kind of problems are you having?
Old 01-19-2005, 09:40 AM
manomite
manomite's Avatar
Default plugs were done this summer
wires look great and worked fine till the other day.I'm measuring the ignition coil and primary wire voltages and ohms today to see what i get.I indicated that the spark wasn't strongg enough in my post because it was barely visible at the spark plug.Thanks will post results.
