Look Here Help Me!! Engine Turning Over!!
hi everyone, recently my engine light came on. i dont know what happend, but ever since that happend, my car had trouble turning on (like it chugs for 3-5 seconds and then turns on)
i currently own a 1998 accord coupe v6
there are a few things i looked at:
air filter
gas cap
spark plugs
ignition switch(changed today)
i was thinking about another solution to the problem, but i am not sure if this is the way to correct my engine starting problem
"The main relay contains 2 individual relays. One relay is energized whenever the ignition is on. It supplies battery voltage to the ECU (computer) to power the injectors and also supplies power to the second relay. The second relay supplies power to the fuel pump. The second relay is energized for 2 seconds when the ignition switch is initially turned on and when the engine is running."
the thing is, when i leave my key on the "ON" position and i wait 2 seconds i can turn on my car fine. but if i quickly turn on the car without waiting for the main relay to supply power to the second relay, the car starts chugging and has trouble starting.
i was thinking if i had to change the fuel filter? or something else.i dont think its the EGR port clogging though, because my car has only 34K miles on it.
someone help. i'll love you to death if u do
air filter
gas cap
spark plugs
Korean Member
http://www.hondainfo.com/troubleshooting.html
If engine light comes on -> Check your O2 (oxygen) sensor..
I hope this helps..
I hope this helps..
didn't honda do an ingnition recall? check to see if your model is on the list. i think it might be. check here for details ... http://www.ahm-ownerlink.com/login.asp?brand=honda
YEA RIGHT! i went to do the ignition recall still didnt fix anything.
so it cant be the ignition switch. im not sure if its the fuse though.
what about faulty wiring, could that be it?
Civic2Scooby
12-23-2008 10:08 PM
MitzEclipse
28
09-22-2003 02:58 PM
Duff Man
05-18-2003 11:45 PM
nando11211
8
01-21-2003 08:41 AM
