Tranny fluid replacement v2.0
more meat, more fire
Is it true you could fill from the half inch drive bolt to the RIGHT of the drain plug? I'm asking because the gun won't fit in the space between the filler bolt and the axle. I called a few friends and one of them said you could fill it from there. Looking for confirmation, need to get this done by tomorrow at the latest. My hooptie now sits at my friend's house :wtc:
As far as I know, the half inch drive to the right IS the drain plug..the quarter inch drive which is to the left and a little higher than the half inch drive is where you fill it. If you try to fill from the half inch bolt, which is lower, then you won't be able to get enough fluid in there which would be like filling oil through your oil pan. PiSSiNg IN ThE WiNd.
