98 and up ls changes
Old 11-25-2004, 06:15 PM
gradebg96
gradebg96's Avatar
Default 98 and up ls changes
i've never heard this before, but my friend jsut told me that 98 and up ls's were changed, they supposedly had cams wit different profiles and stuff too, i've never heard this before, i just thought that every b18b1 from all those years were all that same. Does anyone have info on this at all?
Old 11-26-2004, 05:39 AM
MahoneyL80
I want 2 B cool like u!
MahoneyL80's Avatar
from what i have seen the engine from 98-01 on the gs/ls are the same...might be slight differences but all of them were rated at 140 hp from 98-01...from what ive seen and read about..other then that i dont know
Old 11-26-2004, 10:26 AM
gradebg96
gradebg96's Avatar
same here, but someone told me swapping in 98 cams and some other stuff would help out some, not because they are newer, but because they got a diff profile
Old 11-26-2004, 10:54 AM
Snoopy
been there done that
Snoopy's Avatar
the engines were the same. the only thing that changed in 98 were a few exterior and interior things. and all integra's got those changes.
Old 11-26-2004, 11:12 AM
MahoneyL80
MahoneyL80's Avatar
the biggest interior thing i see that changed was that the gs came standard with leather in 01...and the ls didnt come standard with leather
Old 11-26-2004, 11:23 AM
Snoopy
Snoopy's Avatar
http://www.team-integra.net/sections...?ArticleID=480
and to let you know the gs is basically a gsr without the engine
Old 11-26-2004, 11:41 AM
MahoneyL80
MahoneyL80's Avatar
i know this is probably a stupid question...is it possible to do a mini-me swap with the GS and GS-R like you can do with the d16y7 and y8? or should i just shut up now?
Old 11-26-2004, 11:45 AM
Snoopy
Snoopy's Avatar
its called an lsvtec. you can use a b18a/b or b20b/z block and put any b series vtec head on it. its not that simple though. do a search on lsvtec and you'll get more than enough info.
Old 11-27-2004, 07:50 AM
gradebg96
gradebg96's Avatar
they got kits for make it easier tho www.lightningmotorsports.com , ud still have to get the ecu, the head, distributor, n prolly a the water pump, and other stuff too.
Old 11-27-2004, 12:47 PM
Snoopy
Snoopy's Avatar
that kit will make it somewhat easier but to make a reliable lsvtec you'll have to dig into the internals.
