Installing JDM Type R Cluster into 95 LS
I want to buy the JDM Type R gauge cluster for my 95 LS. Does it matter if it came out of a 96 or 98 spec? Will all the wiring be the same. Like will it just be like swapping the a cluster. Thanks
Apathy Kills
Negative, Ghostrider.
Wiring changes will make this cluster swap [nearly] impossible.
you can always swap out the guages and carbon fiber outlay in the JDM unit, and put them in your stock unit.
I have just heard that the obd2 units will make wierd lights come on, and your fuel and temp needles will probobly start reading incorrectly.
but its not impossible, just a few more steps. good luck
Originally Posted by HaHAAHhAHHAH
got any pics of this?
behind the cluster there are like screws holding the guages in place. one by one, unscrew them. I think its like 2 or 3 for each guage. You need a skinny long phillips. and then its just the matter of swapping the guages (and carbon fiber piece if you want) onto your old unit.
