Allignment messed up?
Folks,
Just got new falken zie-512 (went up a size to 205/55/15), had 4 wheel alignment and balance done. 1 week later went to dealer to get car serviced. since started to notice pull to left when on highway...no pull on street....what could be the issue?
wtf goes here?
the highway is tiered in the middle to the sides to help water get off the road. It's probably just the highway. But it'd still be good to get it double checked.
I noticed mine starting to pull a little to the left, alignment checked out fine, never did figure out what was causing it, just have a sporadic pull to L, not a torque steer thing, just a pull.
If you want to see how tire is wearing, jack it up, and use a roller to put paint ont he wear surface of the tire. I figure mine is just following the grooves/ruts in the road. Mine seemed to get worse after a brake job, but the brakes are working perfectly.
