Answers for a rookie
Old 11-08-2004, 07:07 AM
carlitosir
carlitosir's Avatar
Default Answers for a rookie
(i have a 94 gsr)
what does the secondary butterfly (IAB) in GSR really does?
wich one is the wire i need to hook into the computer (from where in the intake is it connected)?
Old 11-08-2004, 07:50 AM
LT
The deer had to die!
LT's Avatar
for the 4901580158th time:
secondaries
A20 i believe is the IAB pinout
Old 11-08-2004, 08:12 AM
carlitosir
carlitosir's Avatar
awesome!!!!
one more question
this guy is telling me that since this my engine is a 94 model there is no connection to the ecu? (the ecu is a obd2 gsr p72)
is the obd1 gsr engine intake second butterfly actuated in a different way???
is he bs'ing me?
thank for the info!!!!
Old 11-08-2004, 09:04 AM
JimBlake
JimBlake's Avatar
An OBD-1 engine with an OBD-1 ECU is the same. The ECU triggers the IAB. You've got an OBD-2 ECU in a '94?? I suppose it's a different pin on the ECU. So maybe he found that it's wired up wrong? Or maybe that guy just doesn't know...
IAB is pin A17 for '95, I don't know which pin for OBD-2.
Old 11-08-2004, 09:29 AM
mslate
mslate's Avatar
Why would you want to disconect it?
Old 11-09-2004, 12:01 PM
carlitosir
carlitosir's Avatar
a couple of guy have told me that it is vaccuum actuatedd
Old 11-09-2004, 12:22 PM
Snoopy
been there done that
Snoopy's Avatar
it is
Old 11-09-2004, 12:44 PM
JimBlake
JimBlake's Avatar
The ECU uses a solenoid valve to apply the vacuum to open & close the secondaries. So... yes & no.
Old 11-09-2004, 06:53 PM
LT
LT's Avatar
actually, when it there is no vacuum it opens the secondaries.
