window problems
Old 11-06-2004, 11:30 PM
teggy410
teggy410's Avatar
Default window problems
I have a 96 ls and the passenger window doesn't roll up or down anymore, could it be the regulator or the switch, and how can i tell? I really cant afford to take it to the dealership, does anybody have the same problem? Any suggestions would be great thanks.
Old 11-07-2004, 04:05 AM
teg92
WHAT OK YEAH!
teg92's Avatar
check the fuse for the window, Or just take off your door pannel and check the window
Old 11-08-2004, 03:26 PM
j87w
j87w's Avatar
Are you sure the passenger lock isnt on? Its the switch on the drivers side power window controls.
Old 11-12-2004, 08:07 PM
tonto0808
tonto0808's Avatar
Does it make a noise when you try? That could tell you if it is even trying to work. Motor could be burned out, I know over time and use they get worn out. I too suggest removing the panel. I have a 96 and mine including the sunroof are getting slow. The dealer said it is just age. My sunroof requires constant lube.
Old 11-14-2004, 12:57 AM
teggy410
teggy410's Avatar
no it doesnt make a noise and the fuses are ok
Old 11-14-2004, 09:43 AM
c_rogue69
wtf goes here?
c_rogue69's Avatar
need a new regulator
