Stroked engine and Compression Ratio
Old 11-04-2004, 09:55 AM
MoBiX
İŞŘs!
MoBiX's Avatar
Default Stroked engine and Compression Ratio
Is it possible (and logical) to stroke a b18 to 2L and make the compression ratio around 8.5:1 to 9.0:1 for a turbo application?
Also which engine would be best to use: the LS non-vtech or the GSR vtech engine?
Old 11-04-2004, 12:08 PM
dubcac
I
dubcac's Avatar
Instead of stroking it, have the block sleeved and bore it to 84mm, that way you keep the same geometry, and don't make the r/s ratio worse. OEM crankshafts are excellent, no need to replace it...and then your sleeves will be stronger and be able to handle more boost. It's possible to get whatever compression ratio you want, depending on what head you use...LS/GSR/B16. As for what engine, use whatever you already have. If you have an LS, you can always put on a VTEC head.
And it's VTEC, not VTECH.
Old 11-04-2004, 01:00 PM
MoBiX
İŞŘs!
MoBiX's Avatar
Whats r/s ratio?
Old 11-04-2004, 01:42 PM
shivers
Moderator Alumni
shivers's Avatar
Originally Posted by MoBiX
Whats r/s ratio?
The ratio between the length of the rod and the stroke of the crank.
2005 s2000
Old 11-04-2004, 03:12 PM
xfactor
xfactor's Avatar
the ls would actually be better for boosting because of the already lower compression ratios.......stroker kit ruins the r/s... the good r/s ratio of honda engines is what give them excellent reliablity with high revs
