5TH Accord with OEM Alarm Wiring Lines
Duh
ok, my 94 EX CAME with OEM alarm, but the prvious owner took off the Controller Unit(D*** head), only leave the wirings and the Connector adapter. I've Installed the aftermarket alarm, able to find most of the wiring lines (power door lock, 12V, ground, but were not able to find the Lines for the dome light, parking light, the for the door sensor (where some1 open the door, it'll go off) i just don't want to through all the hassle and rewiring those directly to the lights and the door. if any1 has the OEM Alarm wiring diagram for 94 EX, then please help me out. thanks
Older Honda Fanatic
there is a parking light wire in the harness comming from the steering collum... it has a large light blue connector under the dash to the left of the steering linkage. There is a red wire with a black stripe there, thats the parking light wire... use a test light to verify.
On the right hand side of the steering linkage under the dash there is another harness, there is a black wire with a grey stripe... thats for the dome light/door pin trigger. Its the GROUND trigger that goes to the dome light... if you ground the wire out, the dome light will come on. If you open a door, the wire will show a ground... giving the alarm the signal one of the doors are open.
www.designtech.com has wirring guides for free if you want the whole thing.
If this dosent help email me and I can take some pictures.
Duh
dang, my thread is WAYYYYYYYYYYYYY off the subject......anyways, thanks Sumaccordguy94, i'll sure email u if u can't figure out those wires, an then again, thanks a lot.
Dimi
4
09-04-2003 09:17 PM
