VSS location on 1996 Accord? can't find it!!!
Still jobless
I still can't find the VSS (vehicle speed sensor) on my 1996 Accord 5 speed.
I see a screw-in kind of thing with two wires coming out on top of the thing, the wire is yellow and black, is this the VSS? I thought the VSS is bigger with a plug?
PANIC NOW!!!
Originally Posted by allbutjdm
its in the ****ing timing cover
If you look straight down below the throttle body you will see a 2 wire harness going to a sensor that is bolted down with one 10mm bolt. That would be your VSS.
its on the tranny towards the firewall. i just sold one cuz i had an extra one from my auto to manual conversion so your in luck, i got some pics i was trying to show to the guy that bought it. dont poor anything on it.
5spd tranny
auto tranny
5spd tranny
auto tranny
yes, you can pour tranny fluid once the vss speedo gear is removed from under the sensor like in my last picture. i usually just poor through the reverse light hole (manual).
