so i guess i fixed my starter. one question though
Old 08-26-2004, 06:12 PM
A_D
Reset?
A_D's Avatar
Default so i guess i fixed my starter. one question though
what i did was i just took some old 4 guage power wire i had laying around from my stereo, put some loops on each end and put it from my starter to my battery.
i've also done that with my grounds as well
starts like a champ now.
i'm just wondering if the OEM wire from the starter to the battery is fused?
i don't think it is, but i'm just making sure
Old 08-29-2004, 12:03 AM
VRGNCD5
cause it's tight!
VRGNCD5's Avatar
what symptoms were you having? My car seems to not like to start very well when it's cold out, every now and then it won't start. If that's all it takes, I'll do it too!
Old 08-29-2004, 09:36 AM
A_D
Reset?
A_D's Avatar
its easy as **** and it fixed my problem.
all it was doing was on the first turn (for ignition) it would be hella slow/weak. and then the next 2 or 3 turns it would be better, then it would fire.
i did this and now its like new
Old 08-29-2004, 10:03 AM
wesside
2005 Evo Rs @24psi
wesside's Avatar
Some times mine just clicks, if I roll my car alittle sometimes that does it. I think there might be a couple teeth missing ???
Old 08-30-2004, 08:27 AM
JimBlake
JimBlake's Avatar
If it blew a fusible link, you'd have NOTHING AT ALL. Probably what happened is either of these...
- Corrosion at the cable ends. Maybe where the cable itself is attached to the connector.
- Some of the strands broken within the insulation.
Old 08-30-2004, 05:05 PM
VRGNCD5
cause it's tight!
VRGNCD5's Avatar
I'm gonna do it this weekend and hope for the same type of results!! I've had the stuff to do it for like a year and a half nowh:
