Fuel Tank Temperature Sensor.... HELP!
I got an accord 4cyl 98 LX...........I just got a check engine light.......... went to the autozone.... did the OBD 2 thingy......... got a code P1456.......... says Fuel Tank Temperature Sensor circuit disfunction...
did anybody else have this problem???? what should i do??? just replace the fuel tank temperature sensor???? will it fix the problem???
Still jobless
engine check light on 1998
Hi,
My friend's car had the same thing happened. We disconnected the positive battery terminal for a few minutes and then the check engine light goes away and never came back. you may want to give it a try.
P1456 means your gas tank & some other stuff isn't airtight like it should be. That's the code you get when you forget to tighten you gas cap. Reset it by pulling fuse #13 in your passenger door jamb, & see if it comes back.
That works if there really isn't anything wrong. But if there's a real problem (& you haven't fixed it), the light will come back after a day or 2.
There isn't a fuel tank temperature sensor! WTF????
There's a fuel tank PRESSURE sensor, but it's only 1 of about 10 different things that can trigger P1456. There's about 6 pages of procedures in the Helm repair manual for that code. It might just be a disconnected vacuum hose.
