Suspension Inquiry
Old 08-17-2004, 05:23 PM
Silhouette
Back in Black
Silhouette's Avatar
Default Suspension Inquiry
I have an 02 Accord I4 and have just dropped it (Tokico Illumina shox, Eibach Sportline springs) and wanted to know if it's true that the rear camber is more thrown off than the front- and that the front can actually go without being kitted so long as I rotate my tires with every oil change or so (7500 miles for my car)? Also, if anybody has Tokico Illuminas, what setting do you ride in? (1-5) since I'm wondering whether to go with 3 for balance or down to 1 for a really soft ride.. Thanks in advance for the responses.
Old 08-17-2004, 06:06 PM
accordhybrid
accordhybrid's Avatar
I have illumina's and i have them on 3F4R
Old 08-17-2004, 09:19 PM
Silhouette
Back in Black
Silhouette's Avatar
Have you tried 1 at all? Also, do you know the answer to my first ? Thanks.
Old 08-17-2004, 09:25 PM
accordhybrid
On most cars the front need a kit and the rears just use the washers though i'm not sure on the 6th gen's. No i have never tried 1 I set mine like htis tried it for a week and left as is i will only change it at the track
Old 08-18-2004, 11:52 AM
flyromeo3
flyromeo3's Avatar
If you go lower than 2inchs on 6th I believe a camber kit is a a must.
Washers dont work on 6th gen i was told.
Accords have negative camber in the rear to begin with. As I think most hondas are like that.
Its not that much of a negative camber but once you drop it, it will show more.
Instead of rotating the tires I would invest in a camber kit.
Gonna drive you nuts changing your tires.
Old 08-18-2004, 01:53 PM
jschmid
jschmid's Avatar
Yes, the rear will be more affected than the front. Up to about a 2" drop, you'll only need rear camber correction, past 2", you'll need front ags well (generally).
No washer trick on 6th gens.
Old 08-18-2004, 02:41 PM
wedley2
bboy Wesley West
wedley2's Avatar
yea, we already got camber kits but might just install for the rear since its only dropped 1.8/1.7
