Hand Brake Light Stays On
hi all i have a question about my handbrake light when on today, and also the redlight that says brakelight both dont wanna go off, what is the problem if those lights stays on? help me please those light are on my dash thnx all i have a honda accord 2 door 94
sounds similar to another post from earlier today.
brake light
Not to be an ass, but search is your friend. :yes:
brake light
Originally Posted by axemansean
The one that says BRAKE is for the brake light on the assend and it might be out. E brake, make sure the brake is down all the way as the light sensor is very sensitive.
I just had this happen this morning, glad I saw this thread. so would draining(of course adding all new fluid) the fluid, and bleeding the lines stop this from happening on a regular basis?
http://www.honduh.com/showthread.php?s=&threadid=6560
I started a thread on here before I saw the post on here. the general solution is its not big deal if your pads are fine.
wtf.....we are all having this problem today....this is weird and funny.
Are ya'll in the East coast. Close to NY cause Its been raining so perhaps moisture is the culprit?
skabone ----sounds like the problem your having is different than mine from reading that post you put on on honduh.
Its the E-Brake Light im referring to and hopefully the same for you.
It seems that when i start up the car in the morning and release the E-brake the light stays on. After a while ( car warms up ) light turns off.
Its not effecting my braking. Master cylinder is fine,
pads are fine. Just the light doesnt go off as soon as the lever is lowered.
I have some dirt and shit inside where the e-brake is.
Maybe I just need to vaccum it up, maybe the dirt is on the sensor or something.
I just find it odd that this is happening all of a sudden.
It cant be the pads because that light only turns on when the e-brake is up or down.
so im just assuming its a sensor thing.
