How to Repairs on 95 Accord
Tech in Training
Originally Posted by apxlink
wrong forum...lol
That stuff is very easy to replace. Usually the cap is held in by two or three screws. First start off by taking the negative cable off the battery (yes you want to do this caz you don't wanna get shocked in case there is any residual voltage left in the lines). Make sure you have a code for your Honda radio BEFORE you do this, if you still have the stock radio
Take the sparks plug wires off the cap, and off the valve head cover on the engine. Remove the two or three screws holding the distributor cap in place (should look like #2 above). Remove old cap, install new cap, with seal, tighten to about snug (don't go too tight), install the new wires back on the cap head, and usually they are numbered as to order in which the wires go, in case you don't, use this as the order:
Spark plugs are also straight forward, use a long extension with the spark plug socket and make sure you coat the threads with a little bit of "anti-seize" coating.
