Slow power window - HELP
Old 08-03-2004, 07:51 PM
YellowFellow
YellowFellow's Avatar
Default Slow power window - HELP
Hey guys,
I was wondering if you have any suggestions with slow power windows. The problem is with my passenger rear widow. It goes down normally (as fast as the other windows) but comes up slow (slower than the other windows). Any suggestions on where I could lubricate? I took off the rear door panel but all the window gadgetry is behind the plastic....I didn't want to remove the plastic. I had a tint job done a few months back....but I don't know if that has anything to do with it. I just noticed the problem a few days ago. Is this a major problem like a sign that the window regulator going bad...or just in need of some lubrication? Any help would be greatly appreciated. Thanks in advance.
Old 08-03-2004, 08:48 PM
98CoupeV6
lots and lots of fail
98CoupeV6's Avatar
Why wouldnt you want to remove the plastic All you have to do is tape it back on
Anyway, your window motor is probably going. Mine is the same way. Makes a creaking noise when going up.
Old 08-03-2004, 08:52 PM
YellowFellow
yeah I know...I'm just a dumbass.....I didn't want to break the seal yet. Crap...I was afraid that the motor is going.
Old 08-03-2004, 09:21 PM
wedley2
bboy Wesley West
wedley2's Avatar
sam thing on my car and my dads lexus, most likly the motor.
Old 08-03-2004, 10:12 PM
accordvtec77
accordvtec77's Avatar
before you go ripping the door panel off, try this: with the window down, clean the strip along the bottom of the glass frame. You'd be amazed how much dirt collects there. Once that's done, spray the same strip and the glass guides with silicone spray. It should free up the glass some. If that doesn't work, then you might actually have regulator issues.
Old 08-03-2004, 11:39 PM
strykernyc
strykernyc's Avatar
only 2 things, motor regulator as they said or u need the rubber "window guide thing"
if u do what they said and it work and if the problem comesback then u need the window guide thing, is like $30, the motor is like $60
Old 08-04-2004, 06:05 AM
bigpsycho
DIESLOW ENT..
bigpsycho's Avatar
yeah i have the same problem with my front driver side window it goes down fast but it comes up fast up to mid point then it starts that dam click noise but on good days (when it rains) it does not give me a problem..
Old 08-04-2004, 06:26 AM
SkiLLz
p.i.m.p.
SkiLLz's Avatar
I'm having the same problem with my front passanger side window. I hope the motor isn't going because from what I've heard, that job's expensive as hell.
Old 08-04-2004, 06:27 AM
bigpsycho
DIESLOW ENT..
bigpsycho's Avatar
isn't the motor just plug and play?
Old 08-04-2004, 08:59 AM
kaliraver69
kaliraver69's Avatar
I have a similar issue with my passenger mirror kinda rattles when going down but not up and makes a squeeky noise as well. Need to take it to the dealership see whats going up with that.
