what tranny for B20B in 94 Integra?
Hey gusy Im thinking of doign a B20B VTEC swao into my 94 integra because of the price of B20s. What kind of tranny will i need? Some engines come with a tranny but obviously that is no good since it is 4wd. Will a ls or gsr tranny work? Thanks P.S. will the b20 bolt right in my car?
Change sig? Lose [quote]!
Depending on tons of things, unmanaged or poorly managed, 4-8psi. Tuned as much as 10, but. . . it would take a great tuner to get those numbers.
Any B-series traanny will work, but since u gota 94 teg, make sure you pick up a Hydrolic B-series. retrofitting a cable tranny is very expensive and time consuming!!, your best bet would be a B16a tranny from civic si 99-01. the ratio's are the same as a ITR, except the Si's dont have a LSD. Only down side is that you'll loose top end, and hiway fuel economy
