How can you tell if an ECU is bad??
Old 07-29-2004, 07:13 AM
s1ngle
clutch slipping boost
s1ngle's Avatar
Default How can you tell if an ECU is bad??
just want to know if i got jacked....
Old 07-29-2004, 07:15 AM
supermac88
not OG but Old School
supermac88's Avatar
your car will not run right at all... I don't really know what specifically you are asking
Old 07-29-2004, 07:17 AM
s1ngle
s1ngle's Avatar
well, what do you mean by not run? like it wont start? check engine light on? runs bad?
I am just curious as to what experiences others have had with Bad ecu's... what they have done. I highly doubt a bad ECU is fixable, is it?
Old 07-29-2004, 07:20 AM
supermac88
supermac88's Avatar
no it's not really fixable the car may or may not start, and depending on what is bad with the ecu it may just run really shitty. Not sure about the CEL.
Old 07-29-2004, 07:28 AM
s1ngle
s1ngle's Avatar
any more opinions?
Old 07-29-2004, 07:59 AM
lkailburn
college kid
lkailburn's Avatar
i hope you didn't get shafted bro
Old 07-29-2004, 08:01 AM
s1ngle
s1ngle's Avatar
aww shaddup.
Old 07-30-2004, 08:24 PM
UmaycallUsQ
UmaycallUsQ's Avatar
you can tell if you have a bad ECU, if it goes out late at night, and robs liqour stores, and wont split the winnings with you. or if you hit the brakes, and the car accelerates.
Old 07-31-2004, 08:30 AM
Paul
Eater of Rice
Paul's Avatar
if your ecu is dead you'd be throwing a code 0, believe me, I've had it happen.
Old 07-31-2004, 08:12 PM
Jafro
I'm made of meat!
Jafro's Avatar
Heheh... code 0. You're right, too. Can you describe how to count the blinks for that one?
If you have a bad ECU, then when you turn the key to the ON position without starting the engine, the CEL doesn't light up for 5 seconds like it normally does, and is supposed to. That light is an indicator that it's going through a test routine. No light=failed test routine.
Some ECUs can be fixed. It depends on what's wrong with them. On DSMs, 90-92 turbo ECU's suffer from a few weak capacitors, which can be replace, and the ECU will work fine afterwards.
