All Motor Set-up for a B18A???
I need some major help in deciding what kind of parts I should get for an all motor set up for my 90 LS. Basically my price range is around 2000-3000, and I'm looking for a mid to low 14's daily driver. Right now I'm sitting at a 15.4 with bolt ons and clutch/flywheel.
Well let me start off with what I was thinking of getting so you guys can tell me what you think of it/what you think I should get instead.
-Exospeed Stage 1 Head (RS Machine Titanium Retainers and with
performance valve springs. 3-angle valve job as well as
hot tank, new valve seals and resurfacing the head.)
-Exospeed Race LS stage 3 cams (with new cam seals)
-Arias 11.5:1 pistons
-Eagle rods (or some kind of aftermarket rods)
-Skunk2 cam gears
-something for more fuel...bigger fuel pump/injectors or an FPR?
-and of course tuning
I know I'm missing parts but it's because I don't know what I need!
Please help me with my all motor set up. I want to spend money only on what I need and what would benefit me in the ways of power/reliability. All comments are welcome. Thanks!
-Skunk2 cam gears
I hate 2003 Noobs.
I would do itr pistons, gsr p72 head, ge ls/vtec kit, aftermarket valves/springs/retainers, ctr cams, 4-1 header with 2.5" collector. I'd say good for about 180+whp and a lot less expensive then straight up building a ls.
ITR pistons- $250
GSR p72 head- $500
valves- $225
GE ls/vtec kit- $200
Skunk2 springs/retainers- $450
CTR cams- $350
Skunk2 cam gears- $200
DC JDM 4-1 header- $300
custom 2.5" piping- $200
2.5" cat- $100
Total Price of Parts- $2775 or less (if I can get some stuff used)
Look good? Also will I need anything fuel related, or will my stock components be fine? What about a different ECU or chip? Thanks.
-Mike
I'll hold off on the valvetrain for now, and will upgrade it when I upgrade to Skunk2 stage 2's sometime in future years.
As for the S100 system, I know it won't work on my OBD-0 ECU, plus I'll have the GSR head which can't work on my stock ECU that doesn't even have VTEC. So what do I need to do to make the LS/Vtec work? Do I just need an OBD-0 to OBD-1 conversion? Or do I need to get a GSR ECU, and does it need to be the same OBD as the head? I'm just confused about this, could you clear this up for me. Thanks.
