Civic Flywheel/Clutch Install (58 pics)
Old 08-14-2006, 06:01 PM
  #51
CeRviX
CeRviX's Avatar
Default followed destructions & it worked... 87 CeRviX Si
read through the thread twice, looked @ all the pics twice
downloaded them to my PC & went to work.
thanks WCS, bought a clutch kit for $85, bought 1/2 breaker bar
& 32MM from Loews Home Improvement & off I went.
1 day to take it apart, 1 day to put it back 2gether
i figger this is how most things in the world get done,
1 person decides to do something, in this case post a
great diy write up, complete with pics.
thx again
I'm gonna sell this thing whenever china comes out with
a car that gets 50 mpg in the city & costs under $10K
its got $200K miles & is in great shape. will post photos
when it comes time...
Old 08-14-2006, 07:15 PM
  #52
westcoaststyle
Still here... sorta...
westcoaststyle's Avatar
I have to say... thanks to everyone for the props. I can't thank you enough for all of the positive feedback I've received with regard to this thread. I'm so glad that its helped as many people that it has and I hope that it continues to help people!
Old 08-15-2006, 04:29 AM
  #53
swaggs21
swaggs21's Avatar
And still no love for the donor car :sad:
Old 08-15-2006, 05:46 AM
  #54
westcoaststyle
Your avatar loves you enough. :db:
Yes, the car in the pics is Chris'. Slap his ass on your way out. h:
Old 08-17-2006, 12:22 AM
  #55
OblivionLord
OblivionLord's Avatar
Youll have to put me on the list for positive comments. Very detailed I must say. Only problems I had was the damn keeper pin and the aligning of the tranny. Other than that it was nothin. I actually took out the whole tranny just to open up the bell housing to replace the Input Shaft Bearing. I read through another guide for that but, loved this guide to get me to it. Thanks
Do more guides with more pics !!!
Old 08-20-2006, 08:26 PM
  #56
Chefboiali
scrotal surge
Chefboiali's Avatar
While pulling the motor, I got to that pin. The dreaded one The one that made me go to the hardware store to grab the 5/16 punch. I'd say it took me 100+ wacks to get it to finally come off :rant: Funny thing is that I didn't give up. Cold beer to follow.
Thanks Westcoast!
Old 08-20-2006, 10:19 PM
  #57
ColeM
Banned
ColeM's Avatar
awesome diy
Old 08-22-2006, 12:28 PM
  #58
CeRviX
CeRviX's Avatar
I beat the sh*t out of that dreaded pin. Couldn't get it out.
Just left the shifting rod connected to tranny.
87 Si has cable clutch & the balljoint/castlenut is 180' flipped
from the later ones. A good whack to the balljoint got it loose.
figgered i saved $500 & learned something in the process.
I thought you had to take the whole damn engine out, till
i read this thread. it rocks, told all my friends about it.
Old 08-27-2006, 02:19 PM
  #59
nonbox
nonbox's Avatar
I have rented a balljoint separator from Kragen but it did not work. How do you get the balljoint loose from the lower control arm without damage? What part of the lower control arm do you hit with a sledge hammer? Will the lower control arm dent or crack?
Old 08-27-2006, 08:44 PM
  #60
OblivionLord
there is a little trick that you can do. While the tire is off you simply raise the hub and get a 14mm or so socket. You'll now want to put the socket in the portion of the arm near the ball joint. The area im talking about is the one that would squeze onto the socket when you lower the floor jack. After you lower the jack, just push down on the hub manually with all you got. Make sure you untighten the lower balljoint bolt but, not take it off completly. After awhile of pishing down, you will eventually hear a loud pop which is the seperation of the LControlArm and the LBalljoint.
Hard to explain unless someone has posted this procedure with pics.
Quick Reply: Civic Flywheel/Clutch Install (58 pics)
