Window Prob
Window Prob
Ok this is the on going prob that I have been having. The rear driver side window has always acted funny on me. Meaning that sometimes it will open with the button from the front driver seat and close fine no probs right. Then other times it still will open fine but then will not close unless I reached back and closed it, with the rear window button. Or maybe sometimes it would only open and close from just using the rear window button. Point and case the dam window will not even open now. Can someone please tell me or give me some kind of clue what went worng and what I have to now change to fix my poor window.
Any answer will be greatly appreciated
lol, i'm starting to have the same issues, i think it's a common problem with accords. I think the best you can do is take the door panel out, and spray some lub where the rollers are, because they tend to stick.
Had the same problem. I could wiggle the wiring harness just in front of the driver side rear door post (visible when front door is open) and the rear window would work intermittently. I unplugged the rubber grommet at the top of the harness and found that the electrical plug hidden there was not snapped together. I pushed it in until I heard it snap and my problem was solved. You may have to take the plastic trim off of the inside of the post to get to the back side of the plug if it will not snap together from the outside.
honura
5
01-23-2004 09:34 AM
97 CIVIC EX
92+ Civic/EL & Del Sol
2
03-26-2003 11:22 AM
juiceweazel
22
07-23-2002 11:29 PM
