High idle after engine swap
Old 08-06-2002, 06:24 PM
LeftCorner
LeftCorner's Avatar
Default High idle after engine swap
I just had a B18C1 put in my '93 Integra with a '95 GSR throttle body & Skunk2 manifold and there was no spot for the FITV so it was left out. But when I start the car the idle jumps to 2500 and will slowly go down to 2000 and then surge back up and it'll do this for about 5 minutes until it settles at 1500. When driving if I let off the gas the idle goes down to about 1000 and then jumps up to 2000 and will settle at 1500. IAC is connected, The idle screw is turned all the way in, PCV connected, bled the coolant several times and all vacuum lines are free and connected correctly. What's left??
Old 08-07-2002, 09:51 PM
wansumadisVTEC
wansumadisVTEC's Avatar
Default BAD TPS?
BAD TPS Maybe??? Check it with one of your buddies that you know is working. Had the same problem with my h22a swap till I replaced it.
Old 08-08-2002, 04:41 AM
Bumnah
So OG it hurts.
Bumnah's Avatar
you've gotta be careful with the tps sensor removal and installation
but i'd def check that out, and your vacuum lines
Project EVA - The Track Package
Project EVA
Old 08-08-2002, 11:52 AM
dubcac
I
dubcac's Avatar
Yeah check your vacuum lines for leaks
Old 08-16-2002, 07:02 AM
MattAntonucci
MattAntonucci's Avatar
I'll put money on it that it's an Intake manifold leak. Check your Intake manifold gasket and you spark plug grommets.
I just did a JRSC on a ZC CRX and had the same problem.
good luck...
Old 08-16-2002, 10:20 AM
Nelson
Administrator
Nelson's Avatar
Default Re: High idle after engine swap
Yea, I have that same problem on my B16... check all the lines, so far it went down after we played with the coolant lines, I also had the problem of it reving up and down upon initial start.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old 08-16-2002, 01:32 PM
LeftCorner
LeftCorner's Avatar
Pretty good guess. It was the t-body gasket. For some reason I was given the wrong one in my gasket set and didn't even think to double-check it before final installation. All is well now. Thanks guys!
Chris N
13
03-29-2004 11:38 AM
aholston
11-25-2003 09:49 AM
menappi
CRX & Pre 92 Civic
10-31-2003 12:35 PM
N2civicsi
Engine Swaps, Tech & Tuning
03-03-2003 07:52 PM
Quick Reply: High idle after engine swap
