what would you pick?
This is for a 6gen coupe 4cyl. Whats better Koni yellow with H&R sport, Neuspeed sport, or used ground controls all are about the same price. I currently have H&R race definately not a comfortable setup. Basically I"m looking for the lowest drop that will provide maximim comfort. please help me out.
Fight Rice
im going with koni yellows with h&r sport. from what ive heard, its a great setup. im not lookinf for a slammed ride by any stretch, but just something with a subtle drop to remove some of the wheel gap, as well as reduce some body roll. hopefully that helps you out a little, not too sure what type of ride you are looking for as far as the amount of drop goes.
if you want a very large drop with a good ride..then you can call ground control and ask for a custom spring rate....altho it'll be kinda hard to get a low drop without a high spring rate..
hnr sport are far superior than neuspeed because over time neuspeed will sag..hnr won't..both provide a 1.75 drop too..so you'll be sitting a lil higher than your race springs gave you
Accord Forum Moderator
Originally Posted by Mr Hyde
H&R Sports & neuspeed Sports are the same exact spring, made by the same manufacturers. Id get the Sports & Konis. Actually for the price, ID get real Tein Coilovers with adjustable Damping.
I have the H&R sports with Koni Yellows. I like it...a nice balance of handling and everyday ride quality. I keep the shocks on full soft for everday, and crank them up a bit for a drive out on the twisties.
You know me...
KYB AGX's and H&R Sports or Neuspeed (whichever is cheapest) is what I'll probably be doing. KYB's are alot cheaper than Koni's and from everything I've heard provide just as good of a ride.
Do neuspeeds really sag? they drop 1.9 and 1.8 vs. h&r 1.5 and 1.2, the lower drop is the only reason I am considering them. I wish H&R had a specific spring rate, like neuspeeds do, F285 R185. Neuspeed's specs are actually super close to that of tein Stech but people say they sag.
