Replacing Clutch Master and Slave Cylinders
Dumped4life
Do I need a flare wrench to get the fluid lines off. And is there anything else special that I would need?
Oh if I do need a flare wrench can you please give me the size that it needs to be (?mm)
I have a 1994 Accord EX btw.
Try an open-end wrench & see. That'll tell you the size, and if you try without pulling too hard, you can see if you can loosen the fittings.
With an open-end wrench it's easy to round off the corners of the fittings. That doesn't always happen, but when it does you'll wish you had gotten a flare wrench. The risk is if the fitting is tight you'll pull hard enough to round it.
AwwsChwA
Engine Swaps, Tech & Tuning
3
04-15-2003 11:17 AM
