how to change alternator belt?
how do you remove the alternator belt on a 95 integra? it seems to go around some engine mount at the bottom of the car. i can loosen the alternator and slip off the belt, but i can't remove it because of the engine mount, or support or whatever it is... help
The 'main' engine mount is higher on that end of the engine, that doesn't have to come off. You can put a jack under the oil pan (with a piece of wood so you don't bend it). Then remove that mount & have at the belts.
ECHC junkee
We're in the same boat man. I went to change both my A.C. compressor and alternator belts this weekend, I saw that mount there and was like AHHH...WTF!?! Any info/suggestions on this would be most helpful. (Although I could just buy a shop manual...hint hint)
Fast_Draw
Accord
4
03-19-2003 09:09 AM
