is it pistons and exhaust that makes the extra 15 in the jdm
is it just the higher compression pistons and the whole ext (2.5 header
test pipe and back that makes the JDM R have 210 hp?
thanks
also are those pistons 11.5 to 1? and,can these items bolt into our usdm
R's with stock computer and run fine?
thanks
Guest
Posts: n/a
Lets see . . .
the JDM Type-R has 200 PS which is equal to 197 HP. This means it has 2 hp more than the US Type-R. These 2 HP is a factor of the header, compression and a few other things.
If you are talking about the DC5R then nothing is compatible and we are not talking aout the same engines. If you are talking about a JDM DC2R then yes you can bolt the pistons in but there are better OEM options.
